ZC swap issues! Plz help
Hey guys, Been a long time since I've been around. Finally got around to doing my DOHC ZC swap on the RT and having CEL code problems.
Car wont start unless I pump the throttle...once it is @ idle 800-1000rpm its good until you give it gas it will bog to 200rpm almost dying unless you pump the gas it will slowly rise over 2000rpm but drives like its got 2 cars pulling behind it.
CEL codes are:
Code 6 - Coolant [FONT=inherit !important][FONT=inherit !important]Temperature [/FONT][FONT=inherit !important]Sensor[/FONT][/FONT] (ECT)
Code 7 - Throttle Position/Angle Sensor
Code 9 - No. 1 Cylinder Position Sensor
Code 10 - Intake [FONT=inherit !important][FONT=inherit !important]Air [/FONT][FONT=inherit !important]Temperature[/FONT][/FONT] Sensor
(I did check the CEL code post with explanations also.. not positive I checked volts right.. never used my multimeter before)
Currently I have tried to replace all the sensors as well as distributor and cyl pos sensor... still have all codes and problem. Been working on trying to get this thing dialed in with problem after problem... just need it running any help would be greatly appreciated!
Willing to start from square 1 if someone has the time to walk me thru it.
CEL codes are:
Seems like you have a wiring issues. The ECT sensor wiring should give you approximate 5V when the ignition is on. I would start by testing that first. This is the same testing procedure for the IAT as well.
Have you calibrated the TPS yet?
If its OBD0 did you wire in the extra cam sensor?
It looks like this http://i14.photobucket.com/albums/a318/ZCCRX/PICT0146.jpg
This may help you to wire it in http://www.quickhonda.net/zc3.htm
Green plug does not have any open spaces.. plug has two wires
Plug has 1 open pin on low corner of picture..
Took some time off work really trying to get this thing up and running in the next week.. again appreciate all the input so far and sorry i have been slackin!
again thanks to everyone that has given input.. been a great help and cant wait to get this ZC swap on the road!
