hey guys i have a stupid question,.
got a quick question. im right in the middle of the transaction so I need help quick.
I have a 1991 wagon RT 4wd. manual.
will a d16y8 block and head fit right into the physical engine mounts?
plus is there anything else that will not fit directly that I am not aware off?
I plan on swapping out the whole d16a6/y8 conversion I have now for the complete d16y8 block and head.
im not really versed on the tranny section as well.
thanks.
thanks.
will all the sensor, dizzy, flywheel, oil pump, water pump, etc transfer over as well?
sensors: yes, I think so
oil/water pumps: I just don't know
flywheel: pretty sure.
You will have to use the oil pan and pickup from your a6, to clear the transfer case.
I know this isn't a very complete answer, sorry. I haven't done this exact combination. Look around on here for the z6 into RT thread, a lot of good info there, and I would think very similar to your situation.
Has anyone actually actually tried to fit the RT4WD A6 sump and pickup on a OBD2 motor?
The pickup and the sump actually dont fit. You can make the pickup work but the sump has a few different holes so it doesnt fit.
I had to use the sump & pickup that came with the motor, I'm yet to see if the transfer case clears....
