***please help clutch goes to floor***
Hello everyone so i have a question. The other day leaving from a stop light my clutch feel to the ground. The clutch cable was tight but it felt the throw out bearing wasn't doing its job. I check the pedals and cable and didnt see a problem. I put a new trans with a new throw out bearing and put it all back together. I am getting the same exact issue. Could it be the clutch cable or something else? Any help is appreciated. Thank you. Also check the clutch and flywheel and it all looked just fine. Also looked in the pedal assembly and didn't see anything broken.
Youre 110% it's not your pedal? Get in there with a flashlight and be good and damn sure. It's one if the most common wagon issues...
This is most likely the problem. Have someone step on the clutch while you are looking at the lever on the transmission. See if it's actually even doing anything. I busted 2 wagon pedal boxes.
Now I thought this as well. Before I took the trans off I went in there upside down with a flashlight and checked. Didn't see anything broken or bent. When you hit the clutch and look at the arm it moves up then stops and I have to take my hand and physically push it down to get the pedal to come back up. The old throw out bearing in the old trans stuck on the shaft because there was a small ridge on the shaft.
If that was true then when you press on the clutch the fork wouldnt move at all would it?
Um honestly I don't think so. I think I just got one for a civic hatch. There wasn't any in stock for my wagon. It was like a week or two waiting to get it. Do you think that could have anything to do with it?
