Rear Diff Bracket
Hey guys,
I have a 91 civic rt4wd, when I'm driving above 60mph I get a lot of vibration coming from the rear diff. Do you guys think its the axles or mounts? I also noticed that part #9 was missing all the rubber that holds the metal shaft in place, meaning that it is free to move around. It hits metal to metal, any suggestions on getting this fixed? Can I remove that part all together? Is its purpose to be balance the rear diff?
Thanks
The mount was shot, im going to fill it to see if that helps. I'm also going to do the mod that helps with the thug sound using the coilover bushings.
