Tach/Seatbelt fuse blowing
Hey all, so a gremlin has cropped up that is causing the fuse for the tachometer/turnsignals/seatbelts to blow. Often times when starting the car.
I've been trying to identify the wire that goes to the tachometer so I can trace it from the distributor back, if anyone knows which one I should be looking at I'd appreciate the insight. My car has an engine swap and a lot of these wires were BS twisted and electrical taped together, so I imagine that's where I'll find the bastard.
Or any other insight as well, let me know.
I want to say it's one of the shielded wires. Maybe orange? Anyway, some sloppy twist-n-tape could well be the problem. The shield wire is straight to engine ground.
