The official "What Else To Do While Swapping In Coilovers" thread..
I want to start hoarding parts that will aid in a little slammage and being new to Hondas, I'd like to get a list going of other things to do "while you're in there" kinda thing.. I don't like half assing and prefer to do it right the first time.
So along with the actual coilovers themselves what else is recommended, needed, or should be addressed as well? Mounts or bushings, control arms, camber kits..? I'm not looking to autocross or win any Stance Wars competitions but I do want be moderately low with a nice ride and proper suspension geometry.
Just coilovers and camber kits (and be sure to check all the bushings in the control arms before you start on the job.)
Needed;
Coilover kit
Camber kits
And dont forget 4 new bolts, the ones that go through the control arms and coilovers, they break sometimes so having them laying around is the best $15.- spend ever.
I'm not a fan of aluminium-control arms (the cheaper types) myself
Depending on how much you have, how long you'll have the car, and how much you care, you could do a lot while the coilovers are out.
End links, ball joints, wheel bearings, bushings, rta bushings, toe links (could do adjustable ones, too), sway bushings, cv joints, new hardware (oem honda, I agree), steering rack boots, and while you're in there, maybe the brakes if they need tending to.
I'd buy all oem honda, energy bushings and rta bushings, and I've had great luck with the skunk 2 pro ii upper a arms/camber and k sport rear camber/toe kit.
To do it right you'll probably drop some coin, but then you'll never have to do it again.
Anyways...things to consider.
Depends how much you lower it, if you are only doing a slight drop you might get away with it, though I would get rear camber arms as the rear gets a lot of camber when lowered. The front not so much unless you drop the height quite a bit. I never ran front camber arms and my Shuttle was fine even when lowered quite a lot
THIS...And i'll second the rear trailing arm bushings. Those are ALMOST always trashed. Rear control arm bushings as well. You will absolutely need front adjustable upper control arms as well as rear upper adjustable control arms. You're camber will be pretty negative when you lower it.
But what about where aftermarket stuff is needed (like the coilovers themselves or with camber adjustable UCAs), what have you guys run, how's the quality? etc etc..
