Need help . How to run bull bar with a traction bar ????
Like the title says I have a 91 rt4wd with an oem bull bar . I'm supercharging my wagon and I wanna run a traction bar but I'm afraid it will interfere with my bull bar . I DO NOT WANT TO CUT MY BULL BAR TO MAKE IT WORK.
Any and all options are appreciated . I've also considered running aftermarket radius arm bushings .
if you are running both pics and info is appreciated thanks in advance
At worst you will have to weld on some new mounts?
You may have to mod one piece or the other (or both!) to fit.
If you need the clearance then go for the bar. which you should be able to massage the bull bar to allow between it and the frame
