Good or bad idea?
I have function form type ones on my 88 rt4wd. I have the adjusting rings/collars threaded as low as they can go without falling off. Would it hurt to just remove the rings? Sorry if this has been asked previously but I didn't want to search for the thread on my phone.
Can you post a pic?
Edit:
I googled,
As far as I see and if I saw the right image, you can remove both the small gold ring and the lower gold ring of the 2 spring-adjust rings and let the top one rest on the red-fastening-fastening section.
:encouragement:
This is how I pictured it after seeing the googled pics.
As a matter of fact this is how my D2 set sits (+a shorter springs)
By removing the 2 rings you get about 2cm more low (0.8 inch)
You can get much much lower by ordering shorter springs.
Never seen allen bolts in Coilover-rings tho.
Usually when there are 2 separate collars, they are tightened together to lock them in place.
I was thinking you maxxed out on the normal possibilities to go lower.
