RT4WD bolt to lock down switch plate
Today I accidently broke off the head to the bolt that tightens down the plate that switches the RT4WD (on/off) engagement.
Has anyone else done this and what was the solution to remove the bolt inside what I am assuming is the transmission housing? It is hard enough to get a proper extension down there, so I am guessing drilling it out from above is not going to happen.
This is for a manual 6 speed 1988 civic wagon.
I am having a clicking/clanking issue when the car is in reverse and I was messing with engaging and disengaging while trying to rule out issues. It is in 4WD mode now and cannot hold in 2WD. I am afraid that it will mess something up with the potential of slipping between the two.
Are there any links of "7 easy steps to remove your transmission" thread?
Thanks for the reply.
As for the easy steps to removing the transmission........Step 1 - Remove engine.
I dont believe there is a thread walking you through removing the engine / transmission. The clicking noise in reverse could be caused by your transfer case and or possible the reverse gear in the transmission. I had the same issue with my 88 wagon after I bought it. If you want go through my 88 wagon build thread and I have photos of the gear and transfer case take. Apart. Ill post photos in here once I'm home from work tonight.
1. Unplug battery
2. Unplug driver side and passenger side shock tower plugs
3. Remove ground wires and starter wire
4. Remove axles
5. Unbolt driveshaft
6. Remove exhaust manifold
7. Unbolt ac compressor if equipped
8. Remove power steering lines if equipped
9. Remove upper and lower radiator hoses, and both heater hoses
10. Remove throttle, clutch, and shifter cables
11. Put a little tension on the engine with a hoist, remove motor Mount bolts
12. Pull it out
Thanks for the info. A link to that would be nice.
You will need to use an engine brace to hold the motor in place from the top though
