after market exhaust
hey guys im new to the forum. i have a 1990 wagon FWD. and im having trouble finding an aftermarket exhaust system. any products or ideas ?
  • bkmc24bkmc24 Senior Wagonist
    All of the "regulars" are going to harp on searching. It won't lead you to much because there isn't really a wagon exhaust. And if there is, I haven't found one and I am pretty good with parts finding. Go talk to a muffler shop. I got quoted $300 for 2.5 inch catback with resonator and I supply the muffler I wanted. Not a bad price.
  • drfinkdrfink Wagonist
    Nothing bolt on for the wagon. I paid around the same as above for my 2.5" turbo downpipe and my 3" exhaust.
  • As far as headers, aftermarket stuff for the EF Civic/Crx should work fine on the FWD models, but won't clear the transfer case on 4WD, you have to cut and modify any aftermarket header to work. You should be fine with the FWD though. As far as I know , the Catalytic Converters are the same for all 88-91 models, but most of the exhaust after that is different, and like those guys said, pretty sure nobody makes anything aftermarket for the wagon. I've heard that you can make sedan setups work, if modified significantly (can't confirm that though) but at that point, you're better off getting the whole setup done custom.
    Also, Welcome to the forum!
  • All of us "Regulars" harp on searching because the information is there, most just don't care to search. Go to advanced search, put in EXHAUST, make it search TITLES only, and it will pull up 74 threads.
    Do what these guys said, build your own, and if you can't do that, have someone build it for you.
