will these clear?
Will the 195//75/14 BFG All Terrain tire clear on my RT wagon? Have the DA/Accord lift done to it. I think it will be really close. Anybody else ever ran this size?
  • swaggyswaggy Band Wagon
    Those are what I run with a home-made lift. Rears are no problem. Front a little rubbing on the mudflaps and wheel well liner. I used to get punctures almost every trip out running Dunlop sp60s or firestone winterforce. The bfg tire is bulletproof on rocks but due to the load rating won't "float" well when aired down. The tires are very heavy and you will feel it when accelerating. I like the a/ts for 4x4 trips but run passenger tires for daily driving.
  • 503Wagon503Wagon moderator
    If you did the same lift as I did, they should clear no problem. I run a 215/75/14.
  • SwannRT4wdSwannRT4wd Band Wagon
    Im wanting to do the 195 bfg's as well on my rt civic wagon. it is at stock hight tho with the stock rt wheels. The current tire size on it is 185/75r14 so i would be going up one size. what do you guys think before i spend $600 on tires.
