Squeeky noise UPDATE!!!! no more in 2wd mode.
ok so i have had a fun little go around with this car so far. First i put in a TO bearing and clutch kit, then new front rotors/pads/ cv joints. now when i go in reverse i hear a wierd squeeky sound?? also i hear it sometimes really lightly when i am in parking garages (going forward) which leads me to believe it happens all the time just LOUDER in reverse?? it is 4wd and i was wondering if maybe the rearend?? anyone have any experience with this type of noise??? is the rearend servicable?? Also if i unbolt the bolt and make it 2wd can i just take out the rear cv joints and rock it FWD??? thanks
Cheers
http://www.hondacivicwagon.com/board/vi ... ght=#21228
Cheers
So the noise finally progressed to happening all the time...I took the time today to disable 4wd and now no more problems. I had the privelage of being able to work on it on a lift so i could hear exactly where the noise was coming from (which i guess is the Coupling or whatever the thing is in the VERY center of the drive shaft). I also noticed that my rearend was moving around a little too much to me. I guess i will leave it in 2wd til i figure out exactly what the problem is. has anyone made a solid driveshaft with no coupling??? so it is engaged all the time??? thanks
If you have noise underneath I would check the u-joints just to make sure before you replace anything. Just pull the driveshaft apart and make sure they aren't tight or anything.
D
Cheers
