DA rad into wagon
I've developed a hole in my rad. Currently I have some stop leak in it and it's doing the trick.
I have a DA rad since I'm doing a B swap and was told to pick it up.
Now the question is, will it simply bolt right up? I know the hose size is different, but do I need any special hardware, or will it simply fit into place?
  • i have a 90-93 integra radiator in my wagon and it fits with no modification. it is mounted with the stock civic brackets too. the hoses were a little bit of a stretch but they fit.
  • civtec350 wrote: »
    Are you running a B series?
    If you have the parts, why don't you just compare them?
    You definitely don't need the radiator for the swap. But it's nice you have it now...
  • The junkyard was having a 50% off sale and it was suggested to me so for $20 why not. My stock rad is still in the car so I wouldn't know what to be looking at really.
    Thanks for the help civtec
  • i dont have a b series in my wagon, only the radiator. i had an lsvtec and 90-93 integra radiator in an 89 civic si.
    HeadBanger wrote: »
    When you do the swap, take pictures and post them in this thread for future reference.
  • HeadBangerHeadBanger Band Wagon
    Wasn't able to take photos due to dirty hands and me not wanting grease and stuff all over my phone.
    However I have a write up in my build thread: http://www.civicwagon.com/showthread.php?17846-Gandalf-My-91-Wagon&highlight=gandalf
    It's not too serious of a write up, but it lets you know the struggles I went through.
    i'm 99% sure I too have a DA rad in mine, and no modification was required what-so-ever. 99% sure.
    headbanger.... what is that in your avatar? in any case, :encouragement:
    The reason I have an issue is because there's a little rectangular block on the rad that sticks forward a bit and touches the hood. Maybe a different year, or aftermarket rad wont have that same block
