engine rebuild question
so.... my trusty 87 rt4x4 seems to be losing a step at 140,000 miles. it is the 1.5 litre 3 barrel carb 5 speed version. it still runs ok but seems to be slowly losing power. i can still drive it every day but think it may be time this summer to maybe do a rebuild. i need to do a compression/leak down test to see if engine will need to come out or just head work.
so question i have is, what are my options? will a different head/carb work on this motor that will let me do away with all the vacuum crap. i have heard of just replacing engine with a totally different one but don't know what kinda pain that would be. i am not looking for speed or high hp. i am ok with the stock 1.5 but hate all the vacuum lines and seems like a huge pain to remove that stuff for different carb set up and make it work right.
ideally a different head/carb set up on stock 1.5 would suffice...
i just don't know that much about em so thought i would ask before i start working. just trying to get a plan together.
That said, I would recommend just pulling the bottom end and rebuilding it too. You don't want to pour a bunch of time and money rebuilding the head, just to have the rings start to lose seal 15k down the road. Just my .02
