toggle menu
civicwagon.com
civicwagon.com
Sign In
Register
Sign In
Register
Sign In
Register
Home
Electronics, Fueling & Air Conditioning
Need answer now! Fuel sending unit.
ee4wagoon
Wagonist
January 2014
in
When I fill up it goes just above half tank. 3 miles later it's at empty. What is the probably. How do I test out the sending unit? I can't find one can I take it from another EF?
NZ-DB8R
Moderator
January 2014
It should just be a float inside the tank, as it moves through its range it alters the resistance of the circuit and thus the voltage to the gauge
I would check that the float isnt bent or damaged and then I guess the next thing would be the resistor track which it runs on could be worn?
At least thats how a fuel level sender has worked on another car I have worked on
Sign In
or
Register
to comment.
