Is it normal for front coil overs to be set at different heights to make front ride height level? and if not what could be the cause and the cure? Thanx
we are dealing with freezing temps and snow right now but as soon as i can i will post them. Also does anyone know if lowering our cars can cause excessive wear and tear on the steering rack?
if you do have full coilovers than a corner-weighting would be ideal. not necessary for most. Just get it level enough that you're happy then get that alignment redone!
I notice mine stock sits a little high on the drivers side with no one in it.
