my new exhaust
i used 2.5" from the header back. made all of the bends by doing pie cuts. finnaly got some new pics for you guys. it goes under the drivers side of the lower control arms.
the muffler i used is from TSC (tractor supply co.)
the rear section of the exhaust
close up of some of the welds
the pic only just popped up soon after i posted then i saw it came the opposite side. currently mine goes through the center piece on the rear cross member (its was a temp. exhaust set-up) but i plan on routing it the way you have (just the opposite side) next to the LCA and have it bend back into the "stock" position. ..did i make any sense?
This last pic looks awesome, almost as if you had some kind of grenade launcher back there instead of a muffler.
The pics you've posted so far look like you've done away with the cat and resonator. Is that right?
