Axel help please. I searched and found nothing. RT with LSD
so I have 89 civic wagon rt
I did the obx lsd in the rear diff.
what axles am i suppose to use with the rear obx lsd?
Stock?
Stock with d-series inner imputs on them?
I have a slight humm, coming from the pass side rear of the diff.
And d-series front axels dont fit, cause the input is shorter and the axel housing hits the differential housing.
Any help would be awesome.
Thank you in advance!
    So, the original axles don't fit? Sorry, I'm not familiar with that diff.
  • joeyjncojoeyjnco New Wagonist
    they fit, i drove it around. seems fine, lsd def works, does donuts on a dime going both ways.
    But there is humm coming from the rear diff, and i though i read on the old site about needing to switch input shafts. but i cant seem to find the thread anymore.
    I guess i can put it back together and just drive it fingers crossed.
  • The obx is a quaife replica. I would disassemble the diff and reassemble it, torquing to manufacture (quaife) specs
  • So the axles don't spline in? I've only ever heard of obx in a b series, I had one in my h2b swap. Maybe integra inner joints?
