Rear Lower control arms are different 2wd /RT4wd?
Well, I started digging in to my drivetrain swap parts car 88 RT4wd. I started with the rear and I noticed that the lower control arms are a different design than my 90 2wd setup. The bottom of the strut also mounts different. Does anyone Know if this is because the year difference 88 to 90, or because the 2wd to RT4wd difference? I would rather use the 90 2wd stuff because it's in better shape. I have seen pics of other RT4wd wagons that had the solid lowers like my 90.
but, something i've alwyas wondered. is the ball-type stronger? they used that on the ITR right? meaning there must be some sort of advantage in using this.....
what do you think is better. DA or EF LCA?
Their mounting point sits higher than shuttle shocks mounting point.
But OEM shuttle shocks are longer than CRX ones so it all evens out.
