Questions about Plastidip
I have an older wagon, Most of the paint is in bad shape, as well as all the black trim pieces are looking pretty dull too. I recently had a buddy plastidip his rims and taillights, and it ended up looking pretty good.
Anyone have opinions on plastidiping exterior parts of your car? or the whole car maybe?
Did you use any primer or like a clearcoat ontop? or just the plastidip by itself?
http://www.civicwagon.com/showthread.php?12099-Abide-s-1988-RT4WD-Born-on-the-Bayou&p=167680&viewfull=1#post167680 good luck loading all my pics haha.
I think I'm going to be working on some pieces this weekend, I'll be sure to post some pictures.
Before:
After:
With my spoiler and some 'shopped wheels:
It holds up pretty well. I pressure wash and scrub my car fairly regularly. The only places it's peeling is where my ass rubs on the front edge of the rear door when I get in/out, the sill plastic where my foot scuffs when I get in/out and around the lower radiator opening where I found out I needed to score the Plastidip before peeling the tape and had actually peeled the dip up around the edge on accident. It's really easy to do and if you screw up anywhere ( I got a run on the driver's door and the passenger fender cause I thought I needed to put it on heavier than you really do) you can just let it dry, peel it off and re spray. I actually only used two gallons of paint on my car. I haven't fixed any of the peeling cause I'm considering trying another color.
Adam
