DDCWAGON(Silver)
Here are some pics of my '90.
I'm goign to do a 4WD conversion, i purchased an '88 RT4WD.
This site has been a great resource for me so far, check it. :D 8)
    Nice! Car looks great. What all is done to it?
  • TremekTremek New Wagonist
    That's pretty much exactly how I would want my wagon to look.
    wow, nice man!! i love the silver paint 8)
    Nice. Good choice with the silver. Put a lip on it. :D
    That stance looks good, or is it the wheels, look like 17's from here? Either way, pretty dope.
  • Yeah man sweet wagon but that thing needs some lippage on there.
    Nice WAGON!!!!!!
    very nice...
    is that a 4-sqaure snowboard sticker on the back window; if so
    extra pionts for you....
  • thats funky fresh
  • Thanks for the props guys! I decided on the silver after seeing NJ's wagon,that thing is beautiful. For now my 1.5l & AT is stock and sluggish,but I would like to swap a MPFI engine in it when i attempt the drivetrain swap. After looking through the susp. section I decided on some ef hatch springs with my wagon stuts. As for my wheels I chose 17x7 up front & 18x7.5 in tha rear. I tinted it myself with some 5%. I also did the body work & painted it. I want to put a lip on it but I am undecided about witch one to put on. :D
  • just to let you know, you wont be able to run those wheels with the 4wd setup unless you can find tires in both sizes that are exactly the same outside diameter.
    the NJ wagons are infamous and I'd say this wagon has the right look too, clean wagon man, thumbsup!! :D
  • Yeah bummer about the wheels :( ,I was planning on swaping them with my EF hatch . It has 15's. Any suggestions for some lippage?
  • Do a quick search and you will see all the different lips. Accord lip, CRX SI lip (I have on of these), VW lips you have a few different options.
    Putting a lip on there will even out the lines a little bit better. I always felt that Honda forgot the lip when you look at stock body wagons. It really looks like it is missing.
    Put a lip on there and you will see what I mean. :wink:
    i couldn't agree more. it just looks like somethings missing. i'm rocking a vw mk3 lip. look for my thread under member rides to see pics of how it looks
    That doesn't quite work. You need hatch/crx/sedan struts in the rear if you want to use hacth/crx/sedan springs. Otherwise, the back gets lowered lots more than the front. You see, rear wagon struts have a lower spring perch than all the other civic models. Coilovers could work with your wagon struts, but even at the highest setting, the rear will be dropped quite a bit. No biggie, just drop the front to even it out.
    Nice wagon, BTW. Welcome to the site.
