cambering wheels
hey guys theres probably already a thread on this but i was wondering what you guys did for your wheels as far a cambering my tires are wearing really bad on the insides and i cant find a camber kit anywhere help thanks
  • This:
    http://cgi.ebay.com/ebaymotors/RHINO-CA ... enameZWDVW
    Along with this:
    http://cgi.ebay.com/ebaymotors/88-89-90 ... enameZWDVW
    Take it to get it aligned and whoever does it will fix the negative camber.
    Note:
    I don't know about that rear camber kit, it was just used as a reference. I have the rhino front and it works pretty good. I've had it for a while and everything is ok with it.
    ya get those and get a 4 wheel thrust alighment at les shwabs its about $90 also be sure everything is tight like ball joints, inner tie rods out tie rods bushings ect ect.... and no bent wheels!
  • wow that was quick thanks for the quick reply and help i have a question though. Will all civic/crx cambering parts will fit? th only reason i ask i didint see it specified thanks again hey wht do you guys think about this kit?
    http://cgi.ebay.com/ebaymotors/88-91-89 ... enameZWDVW
  • Those kits suck. I used one and they are very terrible. You can only adjust it two ways, and they are made cheap..
    Yes, Civic/CRX is the same as wagon as long as you stay year specific. (88-91)
  • ludesrvludesrv Band Wagon
    Camber actually does only 10% of tire wear compared to toe. Maybe your wheels are aligned properly.
    I used ingalls camber kit in the front (adjustable upper ball joints) and I used nothing in the rear. The rear is not the driving wheels if they are being worn down fast then you have more then just a camber issue. I'd look into worn bushings in the rear causing toe.
  • thanks for the help guys parts in the mail
    Is ur Wgn slammed?If not that camber wear maybe normal.Civic's tend to camber wear(for better handling)which is why you need to rotate the tires.You might start out with a alignment since it sounds like u ordered the kits.
    like stated above camber alone isnt what kills your tires a lil bit of tow in or out along with some negative camber kills tires. and again like stated above dont buy that 2nd camber kit u listed above they are ghetto i know we sell them :roll:
  • yes i bought the brownwagonist white wagon i wanna lower about 1 more inch. I did not but the rear ones i found some that at least do not look as ghetto i hope. Thank you for your help guys.
  • so there was a random piece of paper in the box that said "MAKE SURE YOU GREASE" grease what? inside the rubber covering or outside of it? Sorry if this is a retarded question
  • the balljoint
