Lifted Civic wheel recommendations?
I'm currently in progress of gathering all the parts to lift my Civic like in the lifting a Civic wagon for dummies thread. The OP in that thread says he ended up with 205/65R15 size tires. I like the looks of them, and I'd like to keep some sidewall to my tire if that's the biggest I can go without rubbing, so 15 is probably the biggest I'll go. Does anyone recommend a wheel to go with his combination that won't mess things up offset wise? Is there a Honda wheel (later Civic, Fit, aftermarket) that would fit this setup and give me enough space to avoid any clearance issues?
i had white mini rims on mine until the super swampers with bead lock bassett rims arrived
My Diamond wheels are 15x7, 4" backspace. (Zero offset, since backspace is measured from the outer lip of the wheel, and rim width is measured inside the bead seat). I couldn't find any wheel to suit me in 4x100, so I ordered custom. If I had it to do over, I'd buy Bassett wheels from Circle Track Imports.
For what it's worth, I run 205/60/15s on fatfives on my 2wd daily wagon. No problems, even with the added weight of the b20 swap.
Thats quite odd, CR-V run 205/70R15 tyres stock and their front upright is identical to a Integra/Civic one (same length etc so one would assume same geometry) and they have +55et wheels and they dont rub at all
