Oil Pan Gasket
Hey guys,
I just picked up a 91 rt4wd wagon, but it has a leaky oil pan gasket. I'm in the process of replacing it, I've been doing some researched and it seems that I need to take off the transfer case bc two bolts are blocked off by the case. I've been looking for the helms manual to the rt4wd, but can't a pdf or torrent.
When I remove the transfer case is everything pretty easy to remove, or do I have to be really careful when doing this?
Here is a link I found with some information from the helms manual.
http://www.civicwagon.com/showthread.php?4262-RT4WD-how-to-drop-the-oil-pan/page2
is there a specialty tool when removing the transfer case? or clips that are going to come off when removing the transfer case?
Thanks guys
Thanks guys
