RT Transmission vs CRV Transmission
which trans is stronger?
which has better gears for daily driving?
Which one do you all think will be best suited to a B18C1 turbo?
im aiming for a mild 300 daily driven hp and want to make sure that i have the better trans for the job. i can be a little aggresive from time to time but its about 85-90% normal driving.
so should i crv swap or b2d swap? i dont mind doing the work just want to make sure i make the right choice and have the trans that will take the power and abuse that gets thrown at it from time to time. thanx.
Single cam RT with a healthy z6 and the right turbo should get ya where ya wanna be. If you want B-series thats a whole new can of worms. look around a few guys have done it. if ya realy wanna be a baller k20 AWD that bitch which I believe only 2 guys have pulled off.
