Valve Cover gasket
Can anyone tell me what Acura Intergra valve cover gasket is compatible with my D16A8??? I believe the 88-89 Integra used the same valve cover gasket that I need for my D16A8.
CHEERS
CHEERS
but yes, the 88-89 integra valve cover gasket will work for you
ZC Parts list.
Timing Belt : 88 Prelude 2.0 Si Part # 14400-PK2-004
Water Pump: 88-91 Civic/CRX Si Part # 19200-P01-004
Alternator Belt 88-91 Civic/CRX Si Part # 31110-PM5-305
88 Clutch Kit: (21 splines on input shaft) 88 CRX Si
89-91 Clutch Kit: (20 splines on input shaft) 89-91 Civic/CRX Si
Thermostat: 89-91 Civic/CRX Si
Valve Cover Gasket: 89 Integra
Spark Plug Seals: 89 Integra
Radiator Hoses: Upper 84 Accord 1.6/1.8 Lower 88-91 Civic/CRX Si
Distributor (-cap and rotor): 88-91 Civic/CRX Si
Cap and Rotor: 89 Integra/D16A1 Cap and Rotor only.
Oil filter: 88-00 Civic ( I actually use the S2000 filter)
Exhaust Gasket: 89 Integra
Spark Plug Wires: 89 Integra
Spark Plugs: 89 Integra or 88-91 Civic/CRX Si
Head Gasket: 89 Integra
Intake Manifold Gasket: 89 Integra
Oil Pan Gasket: 88-91 Civic/CRX Si
Throttle Body: 89 Integra, or 88-91 Civic/CRX Si
ECU: Integra PG7, 88-91 Civic/CRX Si PM6, ZC PM7
Header: 88-91 Civic/CRX Si
Thanks
