Grizle's 1989 CRX dx b20b/b16 trans build
So I'm new here, and I figure I would show my most recent build. This time ill post in the correct section though...
This car has been my baby for the past 4 years. Here is my 1989 Honda CRX DX. Almost every part of this car has been gone through and replaced or repaired.
In March 2010 I purchased the car.
Stock engine before it was swapped out.
Stock rear and old tail lights.
exterior after some work was done.
3/18/2012 The B20B engine was put in. At that time, the following things were replaced/installed.
Engine install in progress.
I recently listed this guy on ebay, and she may be sold? we shall see.
- JDM B20B with ~45,000 miles
- Clutch EXEDY 08800B Racing Clutch Kit
- Flywheel ACT 600110 Streetlite Xact Flywheel
- Innovative B - series mounts
- Timing belt
- Water Pump (GMB 135-1400 OE Replacement Water Pump)
- Hasport Shift Linkage for B-series Engine 88-91 Honda Civic/CRX
- B + M Short Shifter
- SS Brake Lines
- Invidia Exhaust
- Custom DOHC 2.0 Liter Graphics
- May 2012 Battery Relocation & Optima Yellow Top Battery and in-car fuse / volt meter
- November 2012 NEW Headlights both Honda Civic Passenger Side + Drivers Side
- July 2012 TRI-Y Hytech RMF Headers
- July 2012 Slim Rad Fan installed
- July 2012 EDM Wing
- August 2012 4 Falken ZIEX 195/60 R14 86H
- August 2012 Exedium Extended Lugs
- September 2012 New Started Installed
- October 2012 New front wheel bearings
- January 2013 EDT Traction Bar
- February 2013 New O2 Sensor
- April 2013 Richporter Technology TD23 Distributor
- April 2013 Spark Plug Wires + Plugs
- April 2013 New Fuel Filter Installed
- May Chase Bays fuel fliter tuck kit
- AEM Fuel Rail
- AEM FPR
