headlight buzzer schematic??
didn't someone about a year ago post a schematic and a brief how-to on wiring in a piezo electric buzzer as a headlight warning alarm?
I tried a search for 'headlight warning' and 'headlight buzzer' and I went through the 2 page list in the "Electronics & Fueling"
somebody have a better memory than me?
thanks!
...jm.
thanks!
...jm.
If you used those exact search terms then you'll find every article ever with either 'headlight' OR 'warning'.
A better search term would have been "Headlight AND buzzer" or "Headlight AND warning". Hope that helps for future searches.
good to know.
...jm.
Wish I knew this when I had my CRX with the tiny tiny lightweight battery.
If i left them on for 10 mins it would be drained!
Thanks guys!
I bought a $3.49 buzzer at Radio Crap, soldered a set of leads to it (it's a board mounted unit & positive is clearly marked) & installed according to directions.
wouldn't work.
tested the buzzer to the battery, red to positive, etc. worked great.
played around with the side of the fuses attached. nothing better. and yes, my defroster works fine.
went to the radio fuse instead. works perfectly.
well, except that I connected it to the back side of the radio fuse so that if the lights are on with the ignition off, the buzzer sounds but the radio will stay on with the key off. the OEM wiring shouldn't normally do that. doesn't bother me, the buzzer works perfectly if the radio is off, lights are on and the key is off.
...jm.
wished I'd thought of that before the $3.50 left my pocket... I'm a cheap SOB.
same here, good advice!
couldn't you also use on of those things that play music in birthday cards?
just a thought.
so, about the way you wired those the buzzer.. your radio can turn on and off without the key now? cause that is like awesome... i always wanted that, idk why, i guess cause certain european cars can do that.
LOL.
Imagine leaving your lights on and removing the keys and hearing "Happy Birthday".
'Happy birthday, you're buying a new battery.... fuckaaaa!'
did you buy a piezo? i bought a regular buzzer last night and it only worked twice but tried to hook it up many times, i bought a piezo this afternoon and now it works...... :roll:
