new intake noisy motor ? RT4WD
me and my brother put a short in take on my wagon last night. And when i drove home it was pretty loud reminds me of a wrx or something its pretty loud. the intake is probablly 5" long with a shorty filter. is this bad for the car or should i just get a new exhaust to help it breath. thanks
Seriously i have absolutely no idea why people do this. Not only does it not suck any cold air into the engine bay, it increases drag and therefore top speed and fuel consumption go out the window (or the bonnet?).
Intake tube running to a box next to the battery, filter inside, tubes feeding cold air running to the box. It's not like you're going to submerge your car that deep.
is your ecu throwing any codes?
1.) first of all unless the engine check light comes on there wont be a code. so you need the engine check light to be on
2.) the ECU is located under the passenger footwell carpet. pull back the carpet there you will find this bronze thing. in the middle there is a small "window" if the check engine light is on there will be a red LED light blinking in this window.
3.) count the number of blinks/flashes. if there is more then one code it will blink different numbers, for example if you are running a code 4 it will blink 4 times, pause, then blink 4 times again, etc. if you are running a code 4 AND 10 it will blink 4 times, pause, then 10 times, pause, 4 times, etc...
once you find out what codes are being given you can check what they mean over here:
http://www.hondacivicwagon.com/board/vi ... .php?t=671
hope this helps.
PayPal me $99.99 and I'l send u kit to muffle this dreaded K&N sound!
If you so worried about this sound, why have you put SAI on in the first place :?:
thats a start.
