water leaking into tail light compartment
My honda is leaking water from rain inside the rear tail light compartment. It happens after raining. I have garaged my honda since day 1 but being out during the day clearly has made it possible for this to happen. What is leaking? The gasket at the top of the wagon tailgate?, the tail lights themselves? ( This happens to both L and R rear tail lights)/. Need some help here. I want this car to stay with me. Any insight? Thanks.
because i do after a hard rain..and its because of the gasket around the rear tails. very simple to change out, i geuss order from Honda.. idk where else :?
well, i hope this answers your Q
as Gene Hackman would say " that was failing common to that model" and sadly it is very common with our era Hondas.
You can get new gaskets. Many people resorted to ENDING the problem forever by using liberal amounts of Silicone, replacing the gaskets with something that won't dry and shrink over time
You could also drill tiny holes in the bottom of those taillights for drainage.
good luck either way
Wow that's an exact description of what happens to one of my wagons.
my spare tire tub itself never gets water, just under the storage bins on the side.
Common issue worldwide i guess.
Ah well, just a gasket fix, ladies! :P
