Air Conditioning weight.=15.5 lbs(7 kilos)
I pulled ALL of the A/C lines/wires/fans etc. out of my 1991 Wagon, and the total weight of everything was 15.5 lbs. It took about 2 hours total to remove everything, and this was my first time removing an A/C system. This is also the first step towards my wire tuck, of which Ill post about later.
I wanted to make this a seperate post so people could specifically search for this topic.
And the compressor weighs more than the rest of the components put together i am guessing..
idk what the weight of all the other components such as the radiator, lines/hoses etc weigh but as for the compressor itself.. ^^^
Reasonable weight saving considering you can get another 30KG in sound deadening alone. Put the two together and you've removed a small person from your car.
Should I call EPA on your a$$ or A/C was empty when you removed it?
Farfetched, that has got to be the most disturbing avatar I have ever seen.
Is that you?
way to put the effort into the thread! this is the kind of information i am sometimes looking for.
No it is not me.....
:roll:
The other thing we have yet to consider is the weight of the pieces still under the dash. I'm going to have a look at those this weekend, and see how hard they might or might not be to remove.
