jeff's 1935 ford rat rod
well im trading my 1987 isuzu pup to a friend for a 1973 volkswagen squareback( no pictures yet), and this truck. the cab is a 1935 ford pickup chopped between 2-4 inches, and channeled about another
4-6 inches. the bed is from a model a ford, just with no fenders. and the grille is from a 1947 (maybe)dodge power wagon and a custom cow catcher that is not finished yet. the truck is on a 1956 ford f100 frame set up for a small block chevy. it has a 305 out of my old 1982 camaro. the transmission is a th250, and a camaro rear end. the front end is from a 1930 model a with original mechanical drum brakes ( they will be converted to juice disc brakes eventually). i am either going to make the truck a roadster or put a cab on it from a 1949 ford f100, because there is a lack of headroom.
K
i two-toned the drums black, and chrysler blue.[IMG][/img]
[IMG][/img]
nice build and looks like fun
[IMG][/img]
i added a chevy brake booster to a set of civic pedals. the fit was close but i had to add a tab for the top bolts.[IMG][/img]
my new gas tank from a 1953 chevy. we had to heat the filler neck and bent it. we also added a new feed line port.
[IMG][/img]
these are my tailgate hinges that we heated and bent also, because they are from a 1953 mercury drivers door.[IMG][/img]
[IMG][/img]
these are the old spot lights that used to have the handle on them, that i am using as headlights. it originally had a 6 volt twist in bulb in it, so i had to trim some of the inner bucket to fit a sealed beam 12 volt bulb.they are mounted on d series connecting rods, i heated and bent.i also added some cab marker lights as my turn signals.[IMG][/img]
old door handles from a building that work with the original striker.[IMG][/img]
my new drag link that i have to cut down.
[IMG][/img]
and these are the taillights i bought at the swap meet in englishtown n.j. from a 1958 chevy bel air.
[IMG][/img]
this is my radiator overflow bottle an old teapot.
we used a jeep slave cylinder and master cylinder for the hydraulic clutch setup. homemade brackets, and a shortened pedal setup from an old ford i believe.
brake master cylinder is from a 55 chevy, no power brakes.
door handles
front shock mounts
these are my gauges mounted in exhaust tail pipes
gas tank
old milk box for a battery box
this is my shifter handlethat a friend gave me from an old chrysler with a console. they are pretty rare, but i figured the car needed some flash. it had no wood in the handle so my grandfather made them and did a design in it with his old leather working tools. he used a stain that was frozen at one time and he tried wiping it off, and i love the way it looks. it makes it look weathered.
i took an old green mailbox and painted it with duplicolor ground coat and red metal cast. than took some spider web lace from michaels arts and crafts, covered the box and sprayed it with satin black then clear.
added a flange and a filter, and i have a new air cleaner.
i replace the old brass door handles with glass ones.
also a glass know as an oil cap.
i have a 4barrel intake for it, and i got a set of header flanges because we have to make a set of headers since theres not enough room inside the framerails.
this is my brothers model a he brought. he started out with pieces of a 4 door sedan body and made a 2 door roadster pickup. the things awesome.
