aem fuel pressure regulator pressure setting
i am about to purchase the aem fuel pressure regulator. i was wondering if i need to adjust it once i get it or will it be preset to my stock setting?
what is the pressure that i am supposed to be getting on my stock fuel regulator?
i dont plan on upping the fuel the same day i install it. only when i get it tuned so for now i just need a new regulator cause i think my current one is on its way out and i may as well install one that can be adjusted for later use.
    hook up a fuel presure guage before u put it in that way u know exactly what the stock psi is. i think it is 35psi but i never have stock pumps in my hondas for long so.....
  • 949949 Senior Wagonist
    which gauge do you recommend?
  • I use to use the B&M gauge and FPR. You had to cut your original FPR and add the B&M fpr to it but they both worked great.
    i have never had luck with B&M fuel presure guages they seem to just fall apart on me...... i use a summit liquid filled guage its far outlasted my B&M's and the needle stays put.
  • The B&M I had lasted 4 years on the Civic HB I had but as to quality it didn't seem all that bad but not all that great either. It is a cheaper alternative though.
