3rd Gen FWD wagon brake upgrade options?
I have searched this section and found the information for 4th gen, but I have a 3rd gen.
I have found this for 3rd gen civics (not wagons) on redpepperracing: http://www.redpepperracing.com/wiki/index.php?title=Big_Brake_Upgrade
But will this work for wagon? As far as I know the brakes on wagon are different, please correct me if I am wrong. What are the swap options for 3rd gen FWD wagons?
As for that link you mentioned that's for the 4g also.
I couldn't find the posting.
The nice thing about the 3g is if I remember right is a lot of the 1g Integra('85-'89) parts will fit the 3g wgn. like brakes,suspension & eng.Do you have Integras in the Ukraine?That's where you should start the search.
You'll need to check all the following since it's been too long since I modded 3g Civics.Following Integra(Teg) 1g(85-89) parts should bolt on your 3g Wgn.Front rotor/caliper & rear axle along with sway bar rear disc(using your civic axle tube) .4g 4WD Wgn. frt rotor/caliper fits has same size or bigger piston & bigger pads.
Too bad you have a 1.4 carb otherwise the 1g teg fuel injected motor will fit.Maybe you can get a Euro 1g teg carb motor.
Tip: If you do do the 4 wheel disc upgrade be sure to get the 4 whl disc proportioning valve from the teg too.
And, of course I was hoping for more modern options ) but teg1 will work I guess.
