The door window, or the fixed curved one at the rear? No matter, either should fit across those years. Can you describe the problem further, or maybe show a picture?
Truthfully, I've not removed a rear door glass, yet.
Yea. And the part numbers on both are the same. Possible that I'm just not putting it in the right way? But I took special not of how it came out. But I'm just getting frustrated now and almost don't even care that it's gone, haha.
Tim,
Depending if you are close to me I could help.
I usually busy as hell on the weekends with the honey do's but I'm sure I could show ya.
Good News every one!
I got the window in! Had to take out the metal track between the little triangle window to the back. Sucked.
Rbw Thanks I'm in lilburn so a bit out there from you. I could use plenty of other help If you're willing.
Also, what does 'the honey do's' mean?
you must not be married. Honey do this do that bla bla Honey do's are a list of chores your spouse or I guess you mom has you to do before you can go and play in the yard (shop).
I thought all the doors from a wagon were the same.
I know sedans, hatchs and crx's are different 88/89 and then 90/91
Tim,
Rich
