R/T 4wd - Clutch Replacement
Hello All,
Im fairly new to the forum. Im thinking about buying a 89 R/T model. :lol: that needs a clutch ... I wanted to know how hard would it be to change the clutch? Any other stuff I have to change while im changing the clutch?
Any suggestions on a good inexpensive clutch? Also anyone know where I can get a diagram of a "how to" replace the clutch?
Thanks everyone! :D
    Norcal510 wrote:
    ... thinking about buying a 89 R/T model. :lol: ... I wanted to know how hard would it be to change the clutch?
    Not that hard depending on your experience .One man job though a lot easier with a buddy.I even did it w/o the clutch alignment tool.Borrow a balljoint separater (don't use a fork(can damage the ball joint boot)). Takes more time 'cuz you need to disconnect the int.shaft & center shaft too.
    Norcal510 wrote:
    ... Any other stuff I have to change while im changing the clutch?
    NO,but recommended items would be pilot & TO brg,turning the flywhl ,see if frt.drive shaft boots are not ripped ,lube the ball joint(see link below) & changing the tranny oil .
    Read +++SiWagon Tip for more tranny tips & a link to the Honda Shop How to Manual:
    http://www.hondacivicwagon.com/board/vi ... .php?t=103
    Additional reading:
    http://www.hondacivicwagon.com/board/vi ... ball+joint
  • Thanks for your help
