Alternator removal Prob
Yesterday the battery light on my 89 RT4WD wagon (manual trans, 128K miles) lit up. A garage checked the battery with a meter and its not getting any charge and I had a bad alternator. Is this likely correct, or should I check other things first? The bad news is he said to replace the alternator, he has to pull the left transaxle shaft and get it out through the bottom. And wants $140 labor to do it. I don't mind paying if there's a lot of work involved, but this surprised me. Is he on the level?.
Honda Shop Manual DOES NOT mention removing the axle.I've NEVER removed my axle when I removed the alt,but those were on 2WDs.
:idea: If you want to save a bundle,when you get the alt. out.Go ahead & take it apart .It's usually bad brushes(only a $1).If you mess up just use it as a exchange.If it works you just saved $150 for a rebuild plus labor(another $140).I've helped friends do this several times.One I help do is still running after 6 years.Ohh don't forget to send me a Franklin($100) for this tip.
Depending on what Alt u got.1 even has a hole to drop in a pin 2 hold the brushes in place 4 assembly (just remember to remove the pin afterward)& the other needs to be soldered in(make sure u use a resin core solder(corrosion reasons)).
However... thinking about it... mine is/was a JDM right hand drive... i think your master cyl and booster are in the way on USDM models? So it might not work.
Since it's ur 1st..double the time.
USDM really looses out on that part, doesn't it?
10mm pipe wrench
deep 12mm socket
short 3/8 extension
3/8 ratchet
then u have easy access to the alternator which should be super easy for ya.
maybe 30 minutes..... i lost a lot of break fluid from my master but after it went back in i filled it back up and the breaks worked just fine i didnt have to bleed it at all.
I did this maybe six or eight months ago on our '88 2WD. left hand drive.
remove the flexible plastic body skirting behind the driver's side front wheel and I think the lower plastic panel on the left side. turn the steering wheel all the way to the left. jacking the front of the car might not hurt, I don't think I did.
remove the alternator & belt, remove the mounting bracket that holds the alternator and set it aside. keep all your bolts organized and then gently work the alt. around, flipping it and turning it like working a puzzle piece, until it gently folds out the side hole in the frame. reinstall the same way only in reverse.
sorry, I'm going by memory here... when I did it I was frustrated for two hours and had an aching back from fighting it until I quit, came inside, had lunch and went back with a fresh attitude. it almost fell out in my hands in fifteen minutes.
...jm.
Thats exactly how i did mine.
from the driver's side. but the lower portion of that side. so, almost the bottom, but not directly out behind the pan.
Anyway, they did a crackerjack job for a fair price. If anyone in the Chicago area is looking for a garage, these guys are good! I got busy, the weather got cold, my son got too busy to help me when the time came, so I just decided to let someone else do it, and I'm glad I did. I don't have a private garage space anymore so it would have been a hassle anyway. They ended up pulling it out from the bottom, and everything worked out, so I am happy. Thanks to everyone for your replies.
Tom
RHD vs LHD is a huge difference!!!
What the hell take the intake out and remove alternator...
If one cannot follow simple R+R instruction, perhaps he/she shouldn
't even touch it!!!
It is my take on it!
