engine bogging... solved=kink in hose
weird thing is is lately it has been progessing to bogg a bit more. i dont know if its a hose or something clogged.
whats happening.
at very light throttle.
keeping at about 2k rpm or 3k rpm.
the engine seems to bogg down.
similiar to something plugging up something like the fuel lines or an air inlet hose.
i dont know what i can be.
anyone else with the same issue?
anyone figured out what it might be?
whats happening.
Cheers1
the cap and rotor are stock i can change those.
any aftermarket performance parts for those?
i just drove the car today. its doing it more often then before.
as for right now its stock. no other mods.
http://www.hondacivicwagon.com/board/vi ... .php?t=104
When was the last time your fuel filter has been changed.Would probably be a good time to change it.
no i have not done any maintenance other then air filter, oil, and oil filter.
The reason I mentioned the fuel filter is 'cuz it's often overlooked in regular maintenance.It's probably NOT either of those parts.
Have u checked the ECU for a code?
this is the first thing that started.
i would prefer to just fix things that are broken or causing problems. as for this it just buggs the crap out of me and worries me at the same time cause i dont want to be stranded somewhere late at night if this issue starts to become more serious.
thanks to everyone's help.
