Oil filter - Proper Stuck!
Hi guys,
I've been trying for half the day to get the bloody oil filter off. I've drained the oil and no luck getting off the filter, I've used a oil filter chain wrench but it was on too tight and nearly pierced the old filter. I had to top up with new oil and leave for another day.
How do you guys take off the filter with out messing it up?
I have a 1.6i 4WD. Any help would be great!
I usually hammer a long phillips screw driver through it for the bottom and use that as a lever to get it moving.
You can try with a belt or some sticky gloves.
1)I use a Lisle 63600 Oil Filter Tool($12 aprx) .U attach a 3/8 drive ratchet to it.It has 2 jaws that squeeze into the filter as u unratchet it.
2)wrap a few rubber bands around the end & unscrew.
3)Use a mouse pad.The foam side has friction.
