Is this a common AC problem? leaks in the pass floor...
is this common for wagons? have anyone had simliar problems with fluid leaking into the passenger side floor?
anyone know how to fix it?
    There's a posting of this prob here some where.It happens to other CRX's &/or EF Civics. :) It's NOT the AC.It's water from out side.There is a FIX.
    the water that's coming in is ice cold i guess from the ac condenser and evaporator under the passenger side. so it's water from the outside??? like when we washed the car or it gets rained on???
    i'm confused becuase it's not raining when it drips.
    thx for the reply, a bit more info could help me, i'll be doing a search to see if i can find info on it.
    check to see if the hose from underneath the evaporator box is still on the nipple that sticks out from it. This is located behind the glove box but down lower underneath the carpet. If its still on then your evaporator compartment is most likely filled with debris and that debris has clogged your drain. Check out the service manual post here on the forum for an EF service manual to see what it looks like.
    BTW wrong section. And welcome to the Site!
  • BTW wrong section. And welcome to the Site!
    oups, thx for the welcome and help
    hmm, where should I move it to? I don't have an a/c section
    I'm a bad admin :oops:
  • 2NR Garage2NR Garage Band Wagon
    locate where the a\c drain tube comes out of the firewall into the engine compartment. Using compressed air,blow up the drain tube and the duck for cover as the rest of the water trapped in the evap box will come out.
    you most likley have a spider web in the tube or debris as someone else has said. this works every time.
