no headlight need HELP as fast as posible
i lost my low beam in the head lights ...
no power to the fuses . i still got the high beam
all the fuses in the dash is working, wen i put on the high beam i get 0,25v on the low beam fuses =/ please help
2)Check that you have ground to the lows.
3)Bad Light switch.
The low voltage could mean bad ground(e.g. frayed wire,loose ground,corrosion @ contacts,etc.).
:idea: Try this turn your headlite on & off quickly like 10-20 x's.This sometimes rubs the corrosion off the contacts in the switch.
