Connecting Pipe Help
I've tried searching but with no success. I'm hoping some of the mechanics on here can assist with this one.
I have a leak where the thermostat housing and the connecting pipe is located. Its' that pipe that runs on the back side of the motor connecting the thermostat and water pump?
I was wondering how easy it would be to replace o-ring and if I can do this without having to remove the block?
Any assistance is welcome.
Thanks,
Chuck
Thanks,
Chuck
Note : I've seen a few of those steel tubes rusted away at the ends, especially in warm climates where people may run straight water with no antifreeze(corrosion protection). You may want to source a spare tube before you tear it down, if it's your only ride.
