turbo question
so heres what im thinking
z6 + y8 head
stock pistons and rods
block gaurd
vx mani with t25 (2g dsm turbo)
walbro 255
390cc dsm injectors
boost controller set at 4-7 lbs
wideband
all in a wagon still obd0 with resistor pack
now the question is how bad will my afr be if i run it with out a tune for a little bit?
z6 + y8 head
block gaurd
walbro 255
390cc dsm injectors
wideband
Also for AFR, almost impossible to predict. You should build it and try it.
Edit: I see you have wideband listed up there. Assuming that's connected to a gauge, disregard my earlier comment about an afr gauge. Also, as long as your rich in boost and running premium gas you should be able to get away with 7 psi all day long.
with an lsvtec turbo basemap, and a street tune from checking plugs. i had a stock bar map sensor, which only reads up to about 11 psi. but like darktrickster says i would at least get the fpr/fmu. i used the missing link and it didnt work for me, but ive seen it work in other cars .
