4wd Hydraulic Transmission Swap
I have a 4wd hydraulic trans that i picked up from a jdm engine importing spot. I was wondering if anyone has any knowledge of what clutch and throwout bearing would be compatible with this trans.
Another question i have for you guys is... What hydraulic pedal assembly is compatible with our wagon chassis? 92-93 integra?
This trans is for a single cam.
[/img]
[/img]
BTW what tranny u have?
S22-2005062
in for pics
They are, but an EG5 RTi is a 92-95 Sedan. :P
As far as the hydro conversion goes i think you'd need a pedalbox, slave cylinder and linkages, not sure what else.
heres the link to the lever setup - http://hasport.com/shop/product_info.ph ... cts_id=171
Its weird though. The eg's have a rear "T" bracket lke the b series and the ef's have the top mount plate with a bracket that mounts to it
