Auto to standard questions.
So my plan is to wait till spring to swap my automatic 89 RT4wd to standard.
Basically all I want to do it put a z6 head on my already existing A6 bottom end and convert it to standard.
obvious things I will need is: p28 ecu, jumper harness, dizzy, axles, transmission, so on.
So what else would I need and most likely run into for the swap?
I'm surprised some1 hasn't locked this thread or moved it.
