How hellaslamD are you going? Post what suspension you're running and what spindles, brakes, axles etc and I'm sure they can help. Moarr info on your setup tho....
You're going to get binding with stock axles at a certain height. Did you just lower the car, if so did you get an alignment? The car should be drivable, you'll just get vibrations and premature wear for the most part. I ride pretty low and I've never broken an axle because of the binding, they just start popping or tear the boot a lot sooner. I'm not sure of any companies that make shorter axles, but you can check Raxles or Hasport, Hasport might mainly do swap axles though.
