Trying to find the right throwout bearing rt4wd
wabashky
New Wagonist
i just posted this is honda-tech this morning with no response yet so i thought i would post here (first post here ever). I am not new to ef's just 4wd ef's. owned quite a few to be exact. here is Rhonda the Honda
anyway, i need to find out if i purchased the correct throwout bearing. here are some pix.
Honda wants a whopping $106 for just the throwout bearing and i got this one for $35 from carquest. Anyone know if i got the wrong one..i havent torn everything apart yet as i am driving it now.
D
D
4WD To brg are Wgn specific.
FALSE. TO's are the same.Other parts different.
As I said earlier 4WD TO brgs are Wgn specific.
You may want to read my +++SiWagon TIP on trannies:
http://www.hondacivicwagon.com/board/vi ... ?p=453#453
According to Honda parts database...which is generally pretty accurate.
1987 4wd: 22810-PH8-008 BEARING, CLUTCH RELEASE (NTN CORP.) $43.16
1987 2wd: 22810-PE6-003 BEARING, CLUTCH RELEASE (NACHI) $29.93
1988 4wd: 22810-PH8-008 BEARING, CLUTCH RELEASE (NTN CORP.) $43.16
1988 2wd: 22810-PL3-005 BEARING, CLUTCH RELEASE (KOYO SEIKO) $34.80
1989 4wd: 22810-PH8-008 BEARING, CLUTCH RELEASE (NTN CORP.) $43.16
1989 2wd: 22810-PL3-005 BEARING, CLUTCH RELEASE (KOYO SEIKO) $34.80
1990 4wd: 22810-PH8-008 BEARING, CLUTCH RELEASE (NTN CORP.) $43.16
1990 2wd: 22810-PL3-005 BEARING, CLUTCH RELEASE (KOYO SEIKO) $34.80
1989 LX 4D: 22810-PL3-005 BEARING, CLUTCH RELEASE (KOYO SEIKO) $34.80
1990 EX 4D: 22810-PL3-005 BEARING, CLUTCH RELEASE (KOYO SEIKO) $34.80
1988 CRX Si: 22810-PL3-005 BEARING, CLUTCH RELEASE (KOYO SEIKO) $34.80
1988 CRX Hf: 22810-PL3-005 BEARING, CLUTCH RELEASE (KOYO SEIKO) $34.80
1990 CRX Si: 22810-PL3-005 BEARING, CLUTCH RELEASE (KOYO SEIKO) $34.80
1990 CRX Hf: 22810-PL3-005 BEARING, CLUTCH RELEASE (KOYO SEIKO) $34.80
So...see a trend?
There is a 4wd specific bearing....that is what ihave said/thought. EVERY parts place (including my Honda dealership) has told em this. If you think about it, if you have a 2wd wagon it is the same as its civic/crx counterpart as far as the driveline goes. the 4wd is COMPLETElY different. Even exedy kits are different for teh TO brg. Anyway, i gues i still havent came up with a solution yet.
D
its all graaavvvy, as long as i get my new clutch in
