Brake bleeding
hi dudes,
i need "step by step" directions on how to bleed my brakes, as they are really mushy from an air bubble (or so i believe). :? basically, what do i have to do :?: i know it is a two person job, which i fine. thanks a alot guys!!
:P
:P
I think I went with what mrwagovan said and they're working great.
if it's the original factory fluid, and you haven't already done the job, you might want to go ahead and bleed it all out till the fluid runs clear at each wheel. you prolly already know this, but don't forget to add fluid after each wheel is done, the level will drop dramatically in the resevoir.
...jm.
