Bobs turbo rt build
88 rt named bob
In the past year I have replaced:
idler pulley (it exploded on me)
clutch
flywheel
pressure plate
pilot bearing
throw out bearing
clutch cable
Things to do before winter:
replace passenger side axle
Winter gathering and build:
bored block 75.5
wiesco pistons and rings
eagle h beam rods and connectors
acl bearings
ferrea titanium valves
crower titanium valve springs and retainers
crower stage 2 cam
I rebuilt the head today actually and am going to assemble the block tomorrow. This motor wont be put in til after winter though.
I am still unsure of the turbo or manifold I will use. There is a lot of things to buy but I have a couple months to do so.
clutch
flywheel
pressure plate
pilot bearing
throw out bearing
clutch cable
bored block 75.5
acl bearings
crower stage 2 cam
go ahead and pm me when you want to edit your post and actually start your thread.
