temp gauge quite working
my temp gauge quite working today. i found a little hole in one of the hoses, my car was leaking antifreeze for a couple of days so i fixed the hose and now the temp gauge wont work. i even changed the thermostat thinking that it would make the thing work but i was wrong. the fan turns on after awhile but not sure how hot it's actually getting.
any experiences/solutions?
  • fixed the prob, my buddy had an engine in his garage and he wasn't going to use it anymore so i took the temp. sending unit and changed it. works good again.
    so, thanks for all your help.
  • 949949 Senior Wagonist
    mine is out too. how did you figure it was the sender and not the actual gauge cluster?
  • kingstep54kingstep54 Band Wagon
    look under the distributor, there should be a round female connector . plug it up . to the male connecter on the head right in that area . u cabt miss it.
